Home > Technical > Emergency Park Brake Release?
DrRob
spooky wrote:
Used this yesterday on my rrs 2013... 3 garages did not know what to do, this forum saved me Smile
Would be good to know how to do this the later rotary gear selector models..... Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #494836 Sun May 01 2016 2:25pm
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Yes exactly! How to do this on rotary selector models!
Kr
M RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #494838 Sun May 01 2016 2:27pm
spooky
Switzerland
Here it is... Indeed a bit different, I just needed to know it's possible Smile
Post #494840 Sun May 01 2016 2:50pm
DrRob
Is there a removable cap in there? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #494848 Sun May 01 2016 5:00pm
LG8340
Hi Dr Rob
Thanks!
That looks familiar. But how did you remove the round plastic cover and what is the procedure to release the park/ brake?
Kr
Michael RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #494849 Sun May 01 2016 5:05pm
spooky
Switzerland
Yes, you see the disk? it can be removed easily with a screwdriver, then you have access to the cable. Then the procedure is the same as with the old RRS, using the jack part which is in the trunk.
Why, oh why is this not in the user manual??
Post #494850 Sun May 01 2016 5:07pm
DrRob
I'll assume the 8 speed rotary is the same but might check to be sure Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #494914 Mon May 02 2016 8:39am
LG8340
On rotary gear selector models access to the parking brake release is straight forward.
The two cup holders can be removed by sliding them up up and out, exposing the release loop beneath.
As for positioning the selector in Neutral for recovery towing the best method is select neutral with engine ON. Then turn off engine and selector knob will remain raised and in Neutral. RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #500520 Sun Jul 10 2016 3:50pm
shakeapaw
just checked, no tool nor screwdriver in my tool kit Sad 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #500525 Sun Jul 10 2016 5:12pm
DrRob
This thread seems to contradict http://www.rrsport.co.uk/forum/topic34685.html
Quoted from the thread:
The rotary knob type (later sport) has a red lever under the cup holder (easy to lift out the way). This is the release from the gearbox being in park (maybe after a flat battery) and you can't use the gear selector. No force need to use this one.
The EPB emergency release is still the old wire loop. This is located under the EPB switch in the centre console. Lift off the flappy bit of plastic in the well of the switch with your finger to expose a pair of screws holding the switch in place. You need a T10 torx to undo these and don't drop them unless you want to dis mental the entire centre console to retrive!
Now lift the switch up (still attached to a cable plug) and in the very narrow gap, you can just about make out the wire loop.
Post #500538 Sun Jul 10 2016 6:36pm
Monffo
2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi there. Just had this problem with my 2010 RRS. I have found the small round plastic cover under the cupholders and have opened it but can't then see what to do. Could you help with a bit more of a detailed explanation please?
Many thanks,
Simon
Post #562198 Sat Jul 28 2018 10:12am
pelle
Sweden
If you have a LHD RRS it is under the copholders.
Post #648373 Sun Jun 15 2025 3:57pm
Wow, that's some thread revival! 7 years between posts. Bow down 2012 SDV6 - it's missing a couple of cylinders
Post #648379 Mon Jun 16 2025 11:16am
