![]() | Home > Technical > Fault code B1211 seat belt pretensioner. |
mark666 Member Since: 31 Mar 2016 Location: Bristol Posts: 7 ![]() ![]() |
Hi all. I have just put my 2011 Sport back together after an airbag deployment. I fitted replacement airbags and seat belt pretensioners along with a new control unit but I am now getting a fault code B1211 "Driver pretensioner ignition squib".
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5109 ![]() ![]() ![]() |
There should be another two digits to that fault code i.e. B1211-11 as there are at least 6 codes beginning B1211
Hi. I have read somewhere that the main dealer scanner has suffixes to the codes but my Delphi scanner only shows the main code. I will get it scanned tomorrow at an independent Land Rover garage and see if I can get more info.
Hi Colin. I went to get the restraints system scanned at the local LR specialist but both his scanners came up with the same incomplete code (B1211) although the Bearmach one did give a fuller description saying that the circuit resistance is above threshold. Could that be a trapped wire?.
Mark,
