![]() | Home > General > Leaking ARC bar |
| Chris80 Member Since: 05 Oct 2015 Location: Kent Posts: 58
I've just noticed my front one has started to leak.
| Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312
Thanks Chris, following your suggestion I have searched this topic & it seems it could be a cheap O-rings replacement issue. So...I have e mailed the garage asking to check the O-rings before getting stuck into what is the expensive option!
You never know!
| URX Member Since: 09 Feb 2009 Location: Edinburgh Posts: 194
Mine went on 2nd RRS and was fortunately 6weeks inside warranty
| Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157
Yep, mine was noticed when car was serviced. 1500 quid for the rear unit replacement. Thankfully under warranty. 2010 TDV8 |
| Rich Member Since: 14 Nov 2014 Location: West Sussex Posts: 39
Mine too. 2010MY. Dealer picked it on service, fortunately just before "approved used" warranty ran out.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
My rear bar was replaced three or four years ago. Thankfully under warranty at the time. 2012 SDV6 - it's missing a couple of cylinders
Thanks all, it seems to be rather more common than I thought... Cross fingers for simple O-rings as I'm only 50% covered on ARC bars |
| htc Member Since: 10 Jan 2016 Location: beds Posts: 15
My 2010 MY started leaking when the car was 5 years (55k miles) old and replaced.
| Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378
My front was replaced last year £1600, my rear was reported to be weeping when it had its mot in march. When booked in to the dealers for the service and cambelt and for the investigation they advised me to leave it for a year or so. There reply was they've had many in with much more of a leak than i had and not to worry about it. |
Where was it weeping from? If the pipe connections then it might be a simple and cheap fix. Leaving it might end up causing damage that does require a bar to be replaced. 2012 SDV6 - it's missing a couple of cylinders
Well the upshot was rear bar replacement not just the o rings. Await the bill but warranty paying half |
Not sure think it was where the ARB entered the actuator, as it was the Actuator that had a fine mist of oil on it. Didnt actually see it for myself. |
| Alexelluk Member Since: 30 Apr 2011 Location: Fife Posts: 22
Hi folks,
| All times are GMT |
