![]() | Home > Faults & Fixes > Starter motor fault |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 ![]() ![]() ![]() |
As long as 4 days? Nice one |
Mmarques Member Since: 09 Apr 2016 Location: Oxfordshire Posts: 76 ![]() |
Haha yep not even a week, must be a record!
It'll be James French you're looking for. Standlake garage is probably the other one down the road. Mine was back in the workshop twice within a week |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Surely if you've only had it a week you would get the seller to replace it with a new one !? |
It would help if you filled in your profile, model, year, engine etc 2008 G4 RRSport TDV8 current
I have sent them an email this morning, awaiting a reply, the car hasnt got any warranty on it. I did update my profile with vehicle details but not sure why its not updating |
Hi camelrock, I did fill in my vehicle details in my profile but for some reason its not updating? Vehicle is a rrs 2006 4.4 v8 petrol |
Unless you bought it privately you've got a warranty.
Thank you socast, I did not know this, I only thought the car would only have warranty if it was added when bought.
The garage I bought mine from took the car in twice in the first 7 days and sorted everything out free of charge. Courtesy car free of charge as well. Good job you didn't buy private |
Thats good that they sorted everything out for you FOC.
Up to you really. I first took mine back as I couldn't lower into access mode. I tested it as working on the test drive, but they replaced the front ARB bushes before I picked it up. One of the height sensors was knocked, I think, which caused the access level fault. The replaced that, gave it a full 4x4 recalibration, all good.
Apart from the starter fault that came up, the other faults arent big, more annoying than anything like the passenger wing mirror has a fault (ive posted a thread about it but no answer yet) it doesnt adjust on the drivers mirror control but it tilts when in reverse dip mode, better explained in the thread, there is a Cv boot which has a small cut in it which I noticed when looking at the car on the forcourt and they said to just get it booked in with them and they'll sort it out foc which was good of them.
CV boot is an MOT fail, if they gave you a 12 month ticket when you bought the car then they obviously cant lay straight in bed. That needs doing sooner rather than later as a dry cv joint can make a mess at worst and cause premature wear at best.
