![]() | Home > Maintenance & Modifications > Interior LEDs |
LeeRRS Member Since: 19 Nov 2015 Location: UK Posts: 43 ![]() ![]() ![]() |
there are kits available on flebay with all the replacement bulbs you need. I wouldn't change them they are far too bright. 2012 Range Rover Sport Autobiography 3.0 SDV6
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 ![]() ![]() ![]() |
There are indeed however they're over priced, considerably, and also don't say which type of bulb they are hence me asking the question. |
Well the kit i purchased just said "all interior bulbs set" if you want to replace just one or two bulbs then i think it's best you remove the existing ones, and if the + and - are in the same place as the replacement. I hope that makes sense. When i installed mine, i had to adjust (push back) the connection terminals to make the LED bulb fit. 2012 Range Rover Sport Autobiography 3.0 SDV6
It does, but how many are 501s, how many are festoon etc |
you got me there mate, i'm not sure. I thinks your best bet is to remove them and order LED replacements accordingly. 2012 Range Rover Sport Autobiography 3.0 SDV6
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
501 are
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5081 ![]() ![]() ![]() |
Glove Box 501 x1
Thank you both that's perfect! |
What are the ones on the underside of the wing mirrors by the way
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Yup |
Thanks |
deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108 ![]() ![]() |
Are these straightforward to fit? I hadnt realized there was lights in there |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 ![]() ![]() ![]() |
I believe they were factory fitted on HSE, HSE Luxury and SC only. Should be pretty easy to retrofit, though, as the generic mirror housing has a space provided for the lamps. Regards etc.,
I have an HSE so I assume they are, I've not bothered to look and rarely drive the car after dark to have realised. |
