Home > Faults & Fixes > HDC, Transmission and ABS error codes
RTG
Australia 2008 Range Rover Sport TDV8 S Stornoway Grey
Many thanks for all the information on the various forums, not only this website, but all the associated ones. This is a little of my issues with my "new" 2008 Range Rover Sport.
I have a 1998 Discovery 1 which I purchased in 2000, and it has been a fantastic workhorse, but it was time to upgrade.
The Range Rover Sport is a vehicle I have lusted after for many years, so I had it for a couple of days, and as I had done many times with my Disco, washed it thoroughly.........even the engine!!!
Even though I used a pressure cleaner, I was careful to spray from a distance. Finished, I started the vehicle, and the dashboard glowed like a christmas tree, with the above errors.
So onto the web forums, tailight, battery, brake light switch, ECU. I removed the battery, removed the ECU from behind it and checked the ECU, which appeared dry. Change brake light bulbs, which coincidentally fixed the HDC as there was carbon buildup and a sheared lens from the bayonet. Still a couple of errors.
Changed the battery, changed the brake light switch, still no joy.
Finally I pulled out the ECU again and had a very close look.
The circled and arrowed chip had a very small amount of salt coloured corrosion across about 5 of the top connectors where the tip of the arrow is. I cleaned it with a 3in1 spray cleaner and a soft toothbrush and let it dry before putting it all back together.
The errors are gone, and hopefully they stay away. Again many thanks for all the contributions on these forums.
Post #494376 Mon Apr 25 2016 7:20am
Paddi
Nice work Thumbs Up
As I'm sure you noticed, there are two ECUs behind the battery; the top one is the transfer case module (TCCM) and the one behind it is the engine ECU. Which one had the problem that you fixed?
Crazy design though - of all the vehicles I have owned only the RRS has these vital modules so exposed to the elements or engine bay cleaning. Usually the various inadequate rubber seals have been tampered with by careless 'professionals' and not properly refitted which only makes the problem worse.
Good idea to search the forum before starting any work on your car - a search for engine bay cleaning would have quickly alerted you to the risk of drowning the ECUs. 2008 MY Java Black TDV8 HSE
Post #494389 Mon Apr 25 2016 11:26am
RTG
The transfer case module. To be honest I didn't notice anything behind it
Post #494390 Mon Apr 25 2016 12:04pm
gogsy1956
So are these 2 Ecu' s the only items of concern when cleaning the engine bay?? 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #494418 Mon Apr 25 2016 5:46pm
RTG
Im unsure. I know my mechanics dont do an engine bay wash anymore due to the ECU issues
Post #494426 Mon Apr 25 2016 8:11pm
Nothing wrong with the design - it was intended for going off road, not getting jet washed! Who the hell fires a hose pipe around near the battery anyway?
As you can see, the design deals with "the elements" quite well:
https://youtu.be/6iUMRY-qK40 2012 SDV6 - it's missing a couple of cylinders
Post #494436 Mon Apr 25 2016 10:05pm
