![]() | Home > General (L494) > Terrible squeaking that sounds like a banshee |
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 ![]() ![]() |
My MY2014 HSE has developed terrible squeaking when under 30mph. Seems to be most common when reacting to a bump, especially with any steering input. Over 30mph it disappears completely.
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 250 ![]() ![]() ![]() |
Another one for a stone, removed the wheels and have a look, is it comming from any side or front or back ? Lot of Landcruisers now sold
No, definitely not a stone.
Have you had the EPB pads replaced recently? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
Possible air suspension issue? I think you're car is off road quite a bit, and the issue disappears over 30mph, so maybe the compressor is having a problem....or leaking air suspension? |
never ready Member Since: 05 Sep 2014 Location: Suffolk Posts: 34 ![]() ![]() |
Mine had a squeak and tapping a low speed, after my second visit to the dealers it turned out to be bent/damaged brake cooling duct. |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
It does sound like a dry suspension bush somewhere. Does it go away or get better in the rain? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
They haven't been changed – the noise is on the move from the front end/underneath – but interested to know why might this make a difference as I use the park brake a lot (I've found that holding the car at a roundabout in 1st on the brake ensures the quickest pick-up). I think it must be something to do with suspension mounts, though. Haven't noticed a difference in the rain but will check if we get wet weather. |
Well, it is still under warranty, so if I were you I would give it back to the supplying dealer, demand a replacement vehicle, and not accept it back until they had fixed it.
It's in for three days from Wednesday to diagnose and fix so if they can't sort it I guess that's what I'll do. It has done 45k in just over 2 years so I think I've got to give them another chance before I get too punchy. Just hope they can work out where the noise is coming from. |
Ended up being a severely worn ball joint at the front. All good once the fault eventually found – I've got an almost completely new front suspension because they've replaced so much... (Through all the time the car was going back and forth the repair centre was a pleasure to deal with, even as they failed to work out what the problem was – maybe because they're not a dealer?). |
