![]() | Home > Maintenance & Modifications > 2.7 TDV6 Oil Pump Replacement |
Ian M Member Since: 19 Mar 2016 Location: Wolverhampton Posts: 2 ![]() ![]() ![]() |
Found the answer to my own question, no woodruff key in the crank shaft |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5122 ![]() ![]() ![]() |
You may want to check if the locking pin is designed to withstand the force of you undoing the bolt. They usually aren't.
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
How did you eventually get the crankshaft pulley off. Does the bolt come off clockwise or anti-clockwise?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
Normal thread, but it's torqued FT! |
Thanks DM, I eventually got the crankshaft pulley off, tight bolt!!!!, but see no woodruff key system on the crankshaft end itself, but there is a key system on the pulley wheel that I removed, how's that works surely it isn't just the force of the bolt that is holding it on?
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Yes it is - just the torque of the bolt holds the pulley in place. 07MY RRS TDV6
WOW! OK that seems insane but explains that side of things then thanks. Any idea what the key/notches on the actual crank pulley do/are for then?
