Home > General > Wheel alignment |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
At most, it should be about half that, or less, depending on what needs doing. Many (most?) dealers don't have alignment equipment but will instead drive it to the local Kwik Fit, get them to do it, and charge you double the amount...
Tue Apr 12 2016 2:46pm |
Ned Member Since: 25 Jul 2015 Location: London Posts: 100 |
Thanks have now booked into Kwik fit welling £43. With 2 new Goodyear excellents fitted
Tue Apr 12 2016 3:12pm |
I wouldn't let kwik fit touch a car for alignment,,as LFW says,look for a local that uses the Hunter alingment system.With the RRS it's not just a case of couple the heads onto the wheel & away you go,,it needs setting up right.
Tue Apr 12 2016 6:43pm |
They tell me that they have hunter haweye , don't know weather they know how to use it knowing my luck I'll get a window licker . |
Tue Apr 12 2016 7:08pm |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
My local tyre fitting garage couldn't seem to get the settings right and they have an expensive 4-wheel laser alignment machine. I went through 2 sets of rear tyres (bald on outside or inside edge) in 3 years.
Tue Apr 12 2016 7:16pm |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 |
i have a mate who is ex lr fitter and he said you need a body shop to do the job right and it takes about 2 hours also i am an ex fully trained tyre fitter and have used lazer light equipment and rrs are a pig you really do have to know what you are doing we would not touch them at our garage if thats any help but dont use q/fit they are rip off merchants we send two women in to 2 differant depots and they can out with huge lists of thing they needed for cars that where fully road worthy |
Tue Apr 12 2016 11:57pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Just had my 4 wheel alignment done by a local body repair shop not know for their keen prices. They wanted £90 (incl VAT). The local stealership wanted £150 so I reckon the repair shop was good value. Seems to make sense that a body repair shop would have all the right equipment if their reason for being is to straighten out bent cars. Robin
Fri Apr 22 2016 3:29pm |
Chris80 Member Since: 05 Oct 2015 Location: Kent Posts: 58 |
Decided to visit TopMarks Tyres this morning in Hooley.
Sat Apr 23 2016 9:07pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 |
Did TopMarks put the car into tight geometry mode to do the alignment?
Sun Apr 24 2016 8:33am |
I did it while sitting waiting as I have my own IID tool.
Sun Apr 24 2016 9:38am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4873 |
Isn't that just a flashy name for Tight Tolerance Mode, just sound more Technical.
Sun Apr 24 2016 9:39am |
Yeah thinks so Col |
Sun Apr 24 2016 9:47am |
Will ask them if I decide to venture up for new tyres... Visitor from fullfatrr.com
Sun Apr 24 2016 10:06am |
A further bit of info on my wheel alignment, here is the report they gave me. Looks pretty comprehensive!
Sun Apr 24 2016 10:54am |
