Home > Technical > Brake Disk Crack
garrycol
Australia
Brake Disk Crack
A neighbour was visiting and indicated that my front drivers tyre seemed a little low.
So I checked it and it was down to 20 psi - while I pumped it back up to 40psi the sun was shining through the wheel spokes onto the brake disk and I noticed what looked like a hair on the disk - on closer inspection I realised I had a cracked disk. Sad
Now these disks are the originals as installed when built and are about 2/3rds worn with just normal wear, no deep wear or warping - I had earmarked these disks for replacement with the next pad replacement but that timetable has changed.
I have ordered local PBR disks to go in but would be interested to know if cracked disks on the RRS is common. The car has never been used for commuting and rarely is braked heavily.
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #492288 Thu Mar 31 2016 10:38am
Socast
I wouldn't worry to much about it, the sport is pretty hard on disks (heavy vehicle and automatic) but I've not heard of any issues with cracking. Have the disks been skimmed at any point ? if not put it down to bad luck and forget about it.
Disks and pads are cheap and easy to swap out Thumbs Up
Post #492309 Thu Mar 31 2016 1:50pm
garrycol
Australia
The disks have never been skimmed as it is something I do not believe in except if there is a gouge or not running true. Yes the cost of new disks is relatively cheap and I have ordered a new set - just was not expecting to do this now. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #492394 Fri Apr 01 2016 2:20am
Russben
Strange how its cracked in the same shape as the brake pads, even a nice neat curve at the bottom. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #492650 Mon Apr 04 2016 11:28am
garrycol
Australia
Russben - I noted your comment and filed it away but that was it - I should have put more thought into why that might be so.
I bought new disks at a good price and paid double what I should have for pads (the ebay delivered price was half the brake supplier).
Decided to replace the brakes and pads today. The pads were only 1/3 worn after 50,000km and of course had issues getting the caliper bracket off but it did come off in the end. I pulled the disk off and located the "crack" which is the same shape as the edge of the brake pad. On looking at the other side of the disk there was a mirror image "crack" and a "crack" where the other end of the pad would be - now getting suspicious.
All looked like cracks so I thought I would clean them up for a closer look under a magnifying glass - I used some cutting compound with no effect so got some wet and dry and the "crack" started to come off.
These are not cracks but "etch" marks on the disk. Just like as if you would do an acid etching on metal. Tough but if you persist they come off. All I can consider is that at some time the brakes were very hot and I stopped for a period with the brakes on and the outline of the pads was etched into the disk.
After sanding the marks this is how the disk looked - same spot as my original pic
I put the vernier calipers on the disks and after 120,000km of use they measured at 27.83mm so still well within limits.
So with one wheel pulled apart - just reassemble or replace - I decided to reassemble and will put new brakes in all round in about 18,000km when the nearest service is due. By then the pads will be about half worn and the disks will be approaching their 27mm wear limit.
Oh - when checking the tyre to remove the little rocks that get in the tread I found a nail so the tyre is now in to get a mushroom plug put it in.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #493324 Tue Apr 12 2016 6:33am
Russben
Glad you got it sorted & updated the post. Thumbs Up
I thought it looked strange having lvely radius cracks.
Mine leaves similar marks occasionally, normally if I've just washed the car, but they wear off eventually when using the brakes.
Russ. I'm in the shed, I'll be back in the real world in a minute.
Post #493332 Tue Apr 12 2016 10:32am
