Home > Technical > Starter breather
Camelrock
Starter breather
Hi all just got the breather to fit onto the starter on a TDV8 is there a tsb or anything on the routing of of the pipe and does the T piece fit onto anything or does it just vent out to atmosphere ?
Regards Ian 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #493316 Mon Apr 11 2016 4:27pm
It runs up by the turbo, across the top of the bellhousing and terminates behind the engine just below the windscreen. Thumbs Up
I'll dig out a page from the manual... 2012 SDV6 - it's missing a couple of cylinders
Post #493317 Mon Apr 11 2016 6:14pm
Sorry, forgot to upload the routing info. I guess it's too late now but just in case:
http://www.rrsport.co.uk/gallery/albums/us...norkel.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #493436 Wed Apr 13 2016 6:45pm
Camelrock
No that's fine RRSTDV8 as not doing the job till Saturday. Just checked the diagram the pipe Lookes different to the breather I've got. I think they have modified the plpe.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #493437 Wed Apr 13 2016 6:49pm
The one on mine is white plastic and fits to two breather locations on the starter (solenoid and motor?). They T together and then runs up to behind the engine. When fitted by the LR dealer, it was just casually positioned to vent below the gearbox! Typical LR dealership quality of work. It was only because I checked whether they'd done it correctly that I found out that they hadn't. Suffice to say the dealership was somewhat surprised when I took the vehicle back and demanded it was done correctly. Unsurprisingly, I had to tell them where the information on the correct routing was to be found.
The reason I was paranoid enough to check is that I'm now on my third starter; the first two didn't appear to have the breather pipe (original install) or to have it correctly routed (second install) and both died prematurely following some wading. I do wonder if the change of wading depth in the manual from 540 to 700mm occurred because LR extended the original short breather. 2012 SDV6 - it's missing a couple of cylinders
Post #493455 Wed Apr 13 2016 9:40pm
Camelrock
Hi RRSTDV8 thanks for the reply wondering if that's what's caused mine to play up as we where court in the flood in the lakes in December and ended up wading through lots of water. Sounds like I might be looking at the breather the wrong way round as I hadn't realised ther where two breather outlets on the starter Embarassed
1994 Dakar current
Post #493465 Thu Apr 14 2016 9:21am
