![]() | Home > Tips & Tricks > Gongs - Key in the Ignition |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
My RRS is 07MY. Had it for 6 years now and asked this same question every couple of years hoping someone has developed a solution, which they haven't.
No, if there was, I could be a rich man, the amount of times I've been asked if its possible.... Bodsys Brake Bible
Hmm figured as such - do you know what scenarios will turn off the gong after 60 secs as happens sometimes. I haven't worked what slight change makes this happen?
I think it's just when the doors are open and you don't open any other doors or change the Ign status. Bodsys Brake Bible
Thanks - I might try a few different scenarios and see what happens. 07MY RRS TDV6
Hmm curious - back ed the car out the garage and parked on the lawn. Switched off and left the key in the ignition in the off position - opened the door and left it open and it gonged for 60secs then switched off.
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
Certain time or first cycle after waking up perhaps? Visiting from DISCO3.CO.UK
Your guess is as good as mine - all seem plausible but nothing seems consistent. 07MY RRS TDV6
Three flash indicators would work, but you also need to update the Body Control Unit. Bodsys Brake Bible
| All times are GMT |
