![]() | Home > Technical > Noise and harshness from transmission |
ash768w Member Since: 26 Mar 2016 Location: southampton Posts: 6 ![]() ![]() ![]() |
Hi all.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2015 ![]() ![]() |
No idea but West 4x4 in Bishops Waltham way are highly recommended on here |
Thanks. i work in Bishops Waltham so that would be ideal.
I'd chuck it back at them to fix it udner warranty.
West 4x4 have took a quick look but they arent 100% on the cause, they got it to do it straight away and said transmission but cant say what part without more extensive diagnosis. i have called the dealer and they have told me they want it taken to their local garage 50 miles away so i have told them to get it recoverd if that is the case as im not risking driving it that far unless i have it in writing that they accept all responsibilty. i'm still waiting for their responce....
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
If you've only just bought it then what's the issue!?
Wot he said ^^^ re: warranty rights etc * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
So I rang the dealer and after he finished with his |
I think the purchaser should return this vehicle to the reseller and ask for his money back in full, as under the sale of goods act, not a good start and you don't know what you have got with this vehicle, future problems out of warranty? Best of luck, but plenty of decent cars out there. ![]() RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 142 ![]() ![]() |
This is a common problem with the ZF6HP26 when used on the BMW's as well. It's usually the partial failure or the failure of the seal between the valve body and gearbox resulting in a drop in oil pressure. It's a £17 part and usually fails around 70,000 miles. Getting to it is a bummer as the valve block & mechatronic units needs removing to gain access. Driving the vehicle in this condition risks further major damage to the gearbox components. |
They have had it since tuesday and i have had no update so i called them.
I personally would reject it now, the garage are obviously giving you the run around and have been since you bought the car.
I agree. Reject it and find another |
