Home > Technical > Special Programs ????
dave421
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi All
Im a felly new owner off a 2008 TDV8 and I'm new to RRS's but I'm learning fast! Every now and then i get Special Programs Off after the system check. Can you please tell me or point me in the right direction that explains what these Special Programs are. I have replaced the battery and i have check the alternator an it holds a constant 14.5v when charging ? How do i turn these programs back on or do they turn back on automatically ?
Thanks in advance for your help
Dave.......
Post #492126 Tue Mar 29 2016 7:57pm
Johnski
Special programs I would take to be the various settings for the various traction for snow, mud, ruts etc.
Another special programs could also refer to the 4x4 pages and FBH remote settings etc.
I'm sure someone will come along with a fuller/correct meanings there of. Very Happy Thumbs Up John
Post #492128 Tue Mar 29 2016 8:15pm
Bodsy
Site Sponsor
You probably don't do many miles in it, or you've put an underpowered battery in it.
It happens when voltage is low. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #492133 Tue Mar 29 2016 8:55pm
gogsy1956
Do a search on here for special programs,,, lots of threads as its a topic that frequently arises. Battery issues are one of the more common faults but blown lamps or cheap non landrover replacements can cause issues. abs sensors or the wiring leading to them has also been found to be a problem. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #492134 Tue Mar 29 2016 9:00pm
dave421
Hi everyone
Thanks for the reply's, as it happens we don't do many miles in it just the odd local journey normally so this does make sense. Do the special programs turn themselves back on ?
Thanks again, very much appreciated Thumbs Up
Post #492135 Tue Mar 29 2016 9:01pm
PEACHY
Yes they do - if the battery charge allows it try scrolling through the special program's looking for the response on the instrument display whilst the vehicle is running but in P or N Thumbs Up 16MY Estoril Blue SVR.............
Post #492136 Tue Mar 29 2016 9:09pm
dave421
Hi
Silly question but you say scroll through the special programs, but how and what are they??
Thanks.....
Post #492141 Tue Mar 29 2016 9:33pm
PEACHY
Shocked below your gear selector there is a programme selector you toggle it left too right. This selects the various 4x4 capabilities for the terrain you wish to travel on - over Thumbs Up 16MY Estoril Blue SVR.............
Post #492143 Tue Mar 29 2016 9:41pm
dave421
HI
Oh lol how funny, now i understand. I didn't realise that was the "special Programs".
Thank you Thumbs Up
Post #492144 Tue Mar 29 2016 9:44pm
PEACHY
As per Lrtopix Thumbs Up
TERRAIN RESPONSE OPERATION
Terrain Response selection is via one of two centre console switches. Depending on vehicle specification, the control switches may include a Dynamic program setting. Use the switches to move through up to five program selections. The currently selected program icon will be displayed in the message centre.Note: Changing between special programs will alter various vehicle settings, e.g., engine revs while at the current accelerator pedal position may alter, or the steering feel might change. These changes are not dramatic but will be noticable.It is advisable to experiment with the available settings in an environment that will not affect other road users.
If the system becomes partially inoperable for any reason, it may not be possible to select special programs. A warning will be given when selection of a special program is attempted. If a participating vehicle system becomes temporarily inoperable, the general program will be automatically selected. Once the system returns to normal operation, the previously active program will be re-activated unless the ignition has been turned off in the mean time.If the system becomes completely inoperable, all of the special program indicators will be switched off and a relevant message will be displayed in the message centre.
A little bit of info - sorry to bore you Rolling with laughter Rolling with laughter ( only the footie is crap ) 16MY Estoril Blue SVR.............
Post #492146 Tue Mar 29 2016 10:01pm
dave421
Hi PEACHY
Thank you the more info the better for me, and yes you are right the football is bad Rolling Eyes
Thanks again Thumbs Up
Post #492147 Tue Mar 29 2016 10:04pm
R444SPT
Assumign the battery is ok, and it is just lack of drive time allowing the discharge you should consider a conditioning charger - CTEK do some great ones, and even better you can charge through the towing electrics if you have them (13 pin or 7S socket (not the N socket). - you can also hardwire a "comfort connector" into place. - Adapter for tow bar charging is available from the shop on here -
Kind Regards
Colin
Post #492173 Wed Mar 30 2016 7:19am
