![]() | Home > Faults & Fixes > Help multiple faults |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
This is only a suggestion, but if you have just had new alternator and battery fitted, I think I would check that all connections and battery terminals are tight first.
| virdi0 Member Since: 28 Sep 2012 Location: Dunstable Posts: 4
All connections are tight. Green flag did the battery test and ok. Charging and holding a charge. The speedo also stopes working. Can you swop the hight sensors from right to left? Just so I can rule out a faulty sensor. Thanks |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Perhaps get Geoff (site sponsor and mechanic) to read the codes for you. Modern cars rely on codes being read to get an idea of the problem |
Just an update. I had the wheel liners off and wd40 all the plugs. I also had the solanod block apart cos the front dropped over a few days. It's now fixed. All warning lights are out and suspension is working as it should. |
| All times are GMT |
