![]() | Home > General > Nervous (about to be) New Owner.... Reassurance wanted! |
Welcome to the TDV8 paranoia self-help group.
ragpicker Member Since: 21 Mar 2016 Location: Teesside Posts: 47 ![]() ![]() ![]() |
Indeed I am, many thanks for the warm welcome!
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
Hi ragpicker
Indeed I do but we'll get flamed if we start talking about the wrong cars especially as I'm an air-cooled 'sandal wearer'
Another welcome to the TDV8 club had mine for 2.5 years had to replace the battery and o/s/r brake calipar, tyres and brakes. Other than that it's been a great car. Other than that as Paddi says above regular oil and filter changes, change mine every 5k. It's easy to read the threads and scare yourself silly but just remember these are just a small numbering of people posting with problems there are a lot of TDV8's out there with no issues, so just enjoy.. 2008 G4 RRSport TDV8 current
Jylee Member Since: 28 Jan 2016 Location: Sugar land, TX Posts: 26 ![]() ![]() ![]() |
Verify the transmission, axle, and transfer case has been serviced. If not, ask for these services as part of the purchase. |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Starting with a one owner, fully serviced car is a great start.
Thanks guys!
For a TDv8 everything that you mention as an "extra" was standard. HSE Lux was a USA model all UK cars were HSE badged or sold as an HST (body kit and exhausts with factory HST's also getting an eDiff)up to 2010, if you PM me an Email address I can send you a scanned copy of the U.K. 2007MY, 2008MY or 2009MY literature (actually there was only one significant change over those 3 model years, phone cradle replaced by hands free Bluetooth system and electrically adjustable steering column and some colors) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks Tim, PM sent!
![]() Look for someone to do a gearbox flush - using a machine that draws out the fluid and replaces with fresh; it is the only way to change all of it in one go. Draining and refilling only refreshes part of it as a lot remains in the torque converter. The active active anti-roll bars (ARBs) are very expensive to replace but prompt changing of the ARB bushes can prolong their life since lateral movement is thought to hasten failures. Whilst you have the car up on the lift have a good look at the diff oil seals especially the front diff. 2008 MY Java Black TDV8 HSE ![]() |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9074 ![]() ![]() ![]() |
Odd that the LR dealer should suggest the ARB bushes should be done in a year's time. If they're showing signs of wear, and if they're original then they certainly will be, they should change them before they get to the point of knocking. They're not expensive - unless you use a LR dealer of course.
Interesting replies chaps, thanks!
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Rear are a doddle, takes around 10/20 mins a side. No special tools needed, two bolts per side (not including the wheel nuts)
