Home > Technical > Can I tow a twin axle caravan on a DETACHABLE towbar?
ezzycozzy
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
I have just bought a RRS 2013 plate HSE with a view to towing a 6 berth twin axle caravan. (Previously towed on an X5 using a detachable tow bar) The car did not come with the tow bar which has led me into looking at getting one sorted out this week only to come across numerous tales of woe regarding a fault on tow bars on RRS's leading to Land Rover recalling cars between 2005 and 2015. The car has an autobiography kit on and any kind of permanent fixture is going to look hideous but is there no other option?
Post #491293 Sat Mar 19 2016 6:48pm
You can tow a big tin tent, many people do. Just as with any towing, you need to keep an eye on the tow bar and makes sure you look after it. Take it out when not being used, keep it and the receiver clean etc. If you're worried, buy a LR tow ball and then get your dealer to carry out the receall check on it. At least then you'll have an idea as to the state of your receiver to begin with. To be honest, if it's been lightly used in the past then it's probably ok. For towing two or three times a year, the removable ball is fine - that's what it's intended to do. 2012 SDV6 - it's missing a couple of cylinders
Post #491295 Sat Mar 19 2016 6:54pm
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
yes is the Answer Very Happy 2007 SUPERCHARGED HST
Post #491316 Sat Mar 19 2016 10:59pm
muddywheels
Milk Float Man
No problem towing twin axle with detachable. I used the same towbar for 6 years on 2 RRS with no issue Thumbs Up
LR are checking existing towballs for wear and replacing if worn so if you're concerned get a dealer to do yours as RRSTDV8 says Cool
I never left mine fitted when not use as I believe weather and theft are a concern Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #491317 Sat Mar 19 2016 11:17pm
Tyrefitter
The answer is yes,I used to tow mine without any problems before I sold it.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #491321 Sun Mar 20 2016 7:25am
DrRob
Consider buying a brand new one though and not one on eBay that was left permanently on a vehicle / used for heavy towing which led to wear in the receiver.
Cheaper than from a LR main dealer:
http://www.paddockspares.com/parts-and-acc...owing.html
Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #491335 Sun Mar 20 2016 10:18am
muddywheels
Milk Float Man
If you buy second hand and see dealer on recall they'll replace it if worn provided you're smart Whistle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #491338 Sun Mar 20 2016 10:49am
midsman
Would confirm yes. We tow a Swift Elegance 645 behind our RRS. No problems with the detachable lowball. Just take it out when not being used. Use the red plastic plug for the RRS latching point to stop dirt etc going in when not in use. Make sure that you clean the towing head with brake cleaner on a regular basis to save contamination of the friction pads on the caravan. Our detachable tow bar was checked and lubricated by the dealer at the last service. 2015 Range Rover Sport Autobiography Dynamic SDV6
2012 Range Rover Sport SDV6 HSE Luxury- Santori Black with Autobiography Ebony/ Ivory interior- SOLD
Post #491347 Sun Mar 20 2016 1:00pm
