Home > Faults & Fixes > Drivers Door Glass Replacement.
PEACHY
Due to my OCD Laughing my next job is too replace the drivers door glass. The current glass is scratched & is more noticeable when slightly opened Big Cry Is the glass replacement a DIY job Rolling Eyes
As always - Thanks in advance Thumbs Up 16MY Estoril Blue SVR.............
Post #491169 Thu Mar 17 2016 10:17pm
Might help,
Post #491170 Thu Mar 17 2016 10:30pm
PEACHY
Thanks Col Thumbs Up
Shocked that second youtube clip makes it look easy Laughing
I've looked on topix for the door card - seems straight forward enough to remove but ideally looking for someone who has actually removed one - the current scratches are Censored me off Twisted Evil
Attempting the new pedal covers tomorrow Laughing 16MY Estoril Blue SVR.............
Post #491172 Thu Mar 17 2016 10:43pm
Hi Mate,
Door cards easy enough just a couple of things, the chrome/noble bit in the door pull handle is a bit of a pain just be gentle with it as there are a couple of the clips that fly in to oblivion on it, one at each end which are a bit of a sod to release, also there are some plastic hook type clips moulded to it as well which are easy to snap off if not care full.
There is a knack to removing the tweeter trim as well, un-pop the plastic clip at the top and pull out slightly and get a long thin flat screwdriver and if you look down behind it there is a plastic lug goes into the door card with a tang on it, you can just release it with the screwdriver and pull the cover up, can do it without the screwdriver but sometimes breaks the lug off and will need a new cover.
Post #491173 Thu Mar 17 2016 10:59pm
Mr Rusty
Scotland 2013 Range Rover Sport SDV6 Autobiography Fuji White
Peachy
What about...http://glassdoctors.co.uk/windscreen-repair/how-to-remove-scratches-from-glass/
No personal experience but might be worth a phone call.
Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
2012 RRS HSE SDV6, Sumatra Black and Ivory
Audi A5, 3.0 TDI, Gone
Audi TT, 3.2 V6, Gone
BMW 5 series tourer, Gone
Post #491191 Fri Mar 18 2016 8:47am
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi mate
The glass is very easy to remove here is my quick step by step.
1. Unclip door tweeter speaker cover 1x clip at the top the cover will stay on the door card when removed.
2. Unscrew all the screws that hold door card on think there is a maximum of 3 or 4.
3. Gently Unclip all the fastens around door once removed remove all electrical plugs.
4. with the window glass in the closed position, get some masking tape and tape it around the top part of the door to stop it falling when you remove the window motor mechanism.
5. Unscrew all the bolts that hold motor mechanism in position once all bolts are removed you'll need to gently tap it as its stuck in with double sided tape around the edges, once this has been done you'll see 2X white plastic lugs where the glass sits in.
6. Unclip window from plastic lugs. Remove motor mechanism.
7. You will now be able to ( 2 person job ) remove masking tape and carefully lift out window it will need various tilting actions but will remove.
Hope that helps.
Post #491195 Fri Mar 18 2016 9:58am
PEACHY
Bow down Bow down thanks gents - as always this forum is the place to be Thumbs Up 16MY Estoril Blue SVR.............
Post #491196 Fri Mar 18 2016 10:18am
ABSport wrote:
Hi mate
Hope that helps.
As Mark say's there are 4 screws 1 each end 2 in middle under noble trim, also need to remove the 1 behind door release handle pop out little plastic cover first easy enough with finger nail.
Post #491197 Fri Mar 18 2016 10:44am
