![]() | Home > General (L494) > Low Battery Warning |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
I would suspect your usage pattern means your battery is having a very hard time, and could well need "topping up". MY2016 HSE D SDV6 - gone due to fuel dilution problems.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
Definitely get yourself a smart charger,,, Ctek are quite popular, and give it a boost overnight once a week, have had to do the same with mine as short journeys weren't doing it any favours. 2010 RRS, TDV8
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 ![]() ![]() ![]() |
Ditto the above.
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 ![]() ![]() |
Love th ctek - even better it conn CTS via 13 pin towing socket!! |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
Did you get the towing socket charger from the guy on the Disco 4 forum? I assume the electric tow bar is 13 pin?
Just used the shop link from the home page of this forum - really quick delivery - suspect same source as Disco 4 forum. |
Thanks, I assume the L494 is 13 pin? I haven't used it yet! And it is a permanent live connection so can be plugged in with car locked? MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
Yes , if factory or Dealer fit, it will be 13 pin,many have a live in there, haven't looked to see which one mind you, it all just worked |
Brilliant I will get an order in. MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
