Home > Maintenance & Modifications > Connection DRL
Thomas
Italy 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Connection DRL
Hello, I bought the drl to be included in the headlights, and I would like to connect them so that when they turn the key light up regardless of the position of the lights, as I do 'inside the headlights there a power from key? where I can connect? thank you
Post #490637 Fri Mar 11 2016 6:00pm
tone 123
England 2005 Range Rover Sport Supercharged Java Black
hi thomas you can buy a drl harness off ebay. £5-£20 connects to the battery. drls light up on turnover. then go off 30 seconds after you turn the engine off very easy to do cheers.
Post #490714 Sat Mar 12 2016 5:20pm
tommymac
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
hi mate, do you have a pic of drl harness required or link where one may be please,,
also do you know how to connect from headlight,
have had led rings installed however not running drl and want to wire up myself,,;
thanks
Post #573229 Wed Jan 16 2019 6:24pm
Have a look behind the grill on the passenger side. (remove grill)
If there is a spare connector there, you can wire it upto the ignition supply on that.
Post #573231 Wed Jan 16 2019 6:31pm
tommymac
Thanks Andy Will look tomoz
Post #573232 Wed Jan 16 2019 6:48pm
connect to the green wire
Post #573233 Wed Jan 16 2019 7:07pm
tommymac
thanks mate great advise,
Will I need a special kind of harness off ebay etc to connect the two together?
Green and white to ignition harness if theres one or is it just a direct connection and connect with a gate connector?
Sorry not the brightest when it comes to RR electrics..
cant be to hard to do though? Very Happy Thumbs Up
Post #573243 Wed Jan 16 2019 8:52pm
Nothing required off ebay
Post #573249 Wed Jan 16 2019 9:34pm
tommymac
Cheers Andy..
Post #573267 Thu Jan 17 2019 8:07am
tommymac
Cheers Andy..
Post #573268 Thu Jan 17 2019 8:07am
jason-nike
I ran mine straight from the fuse box on my old one.
DRL came on with ignition and went off with ignition
Post #573465 Sat Jan 19 2019 9:22pm
tommymac
cheers Jason,
can you advise what pins/colours u connected to on back of headlight and which fuse u attached onto also,,
Cheers mate..
Post #573482 Sun Jan 20 2019 9:36am
jason-nike
I didn't connect drl to headlights, negative was to earthing point and positive was into fuse box, will look for picture of what attached to as sold car last year, but fitted new ones to new car
Post #573553 Mon Jan 21 2019 12:04am
jason-nike
will find a pic
Post #573554 Mon Jan 21 2019 12:04am
tommymac
Thanks jsson
Post #573555 Mon Jan 21 2019 12:08am
