Home > Maintenance & Modifications > Front lower arms
Wayneclarke
Front lower arms
Need to replace my front lowers arms as the bushes are worn, first quote is £746 is this about the right price ??
Post #490444 Wed Mar 09 2016 10:07am
Disco_Mikey
Seems high. I charge £500 inc fitting, using genuine arms...
Post #490445 Wed Mar 09 2016 10:16am
Lost for Words
Probably not so bad for Kent labour rates though, Mike... Visiting from DISCO3.CO.UK
Post #490448 Wed Mar 09 2016 10:23am
Wayneclarke
That is genuine arms and also wheel alignment, first time I've ever had to have this done so not sure what the rate normally is. And I'm guessing it's better to use genuine arms ???
Post #490456 Wed Mar 09 2016 11:14am
cannon-fodder
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
That is around the figure I was given to have mine done, by an independent in Kent (Gigglepin), which included a 4 wheel alignment.
Post #490458 Wed Mar 09 2016 11:19am
flack
Contact Geoff. from D3 forum, he is in Kent and will do you a better price than that.
http://www.disco3.co.uk/forum/member-geoff.html
Flack Thumbs Up
Post #490459 Wed Mar 09 2016 11:20am
Wayneclarke
Yeah maybe worth giving Geoff a go, can he also do the wheel alignment
Post #490460 Wed Mar 09 2016 11:31am
flack
Yes he can do the wheel alignment.
Flack Thumbs Up
Post #490463 Wed Mar 09 2016 11:50am
Wayneclarke
Im now being told by my local garage that it may not be my arms that need replacing but it could be my ARB bushes they need changing, they want the car for a couple of hours to check
Post #490470 Wed Mar 09 2016 1:40pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
ARB bushes are cheap and easy to do. If you get the controls arms done, it's probably worth changing them to.
Post #490589 Fri Mar 11 2016 9:07am
Socast
I would find a new garage, a couple of hours to do a 10 min job is taking the p*ss. I doubt it would take 2 hours to change all 4 bushes.
I changed my lower arms not long after buying my car, I bought a kit from Advanced Factors with SuperPro bushes already fitted. It cost a lot more than a normal set but they will last a lot longer, they do make the ride a bit sharper though.
Post #490591 Fri Mar 11 2016 9:50am
Disco_Mikey
Try changing the front ARC bushes in 10 minutes Laughing Big Cry
Post #490597 Fri Mar 11 2016 11:26am
Socast
I meant 10 mins to check the bushes, back ones can be replaced at 10 mins a side. I've not done the front ones, I looked and decided I would get my local indi to do it haha.
Post #490599 Fri Mar 11 2016 11:31am
