| RRSPORT.CO.UK | ||
|  | Home > Technical > Suspension reading - front n/s is way out |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | you need to go through the eas calibration process and that will most likely fix your problem. Bodsys Brake Bible
|  Tue Mar 08 2016 6:11pm |
|  Tue Mar 08 2016 6:13pm |
| Angie4m Member Since: 30 Dec 2014 Location: Edinburgh Posts: 69      | Thanks bodsy, the values from the middle of the wheel to the bottom of the wheels arch
|  Tue Mar 08 2016 6:29pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | ignore what it looks like on the screen and follow exactly the eas calibration process. this involves measureing the heights, looking at the calibration values, looking at the current calibration figues and doing a bit of maths. Have you seen the calibration sheet? Designed to calibrate left to right or right to left. You then have to lift the front or rear (or drop) to get the front and rear at the right height.
|  Tue Mar 08 2016 6:38pm |
| Angie4m Member Since: 30 Dec 2014 Location: Edinburgh Posts: 69      | I've got the calibration sheet here so I'll work with that tonight. I have a sneaky suspicion that someone possibly the previous owner changed the heights.
|  Tue Mar 08 2016 6:48pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | unless it's a physical fault, then the calibration and ride height adjustment will stop the car going into extended mode.
|  Tue Mar 08 2016 6:53pm |
| Angie4m Member Since: 30 Dec 2014 Location: Edinburgh Posts: 69      | I've not really driven it since I brought it home but it could do with feeling a bit more solid. It didn't feel too bad driving the M6/M74 home.
|  Tue Mar 08 2016 7:32pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | dont do it in increments, the point of the calibration is to calibrate the left side to the right (or vice-versa). Once thats done, you re-measure and then lift or drop the front and rear by whatever the measured values are -465 or -485   | ||
|  Tue Mar 08 2016 7:50pm |
| Angie4m Member Since: 30 Dec 2014 Location: Edinburgh Posts: 69      | Ah, that makes perfect sense Bodsy. | ||
|  Tue Mar 08 2016 8:45pm |
| Angie4m Member Since: 30 Dec 2014 Location: Edinburgh Posts: 69      | Eventually got round to doing the calibration properly today. Now both n/s and o/s are calibrated and front and rear heights have been sorted.
|  Tue Apr 05 2016 9:07pm |
| Posting Rules
