Home > Technical > SatNav Screen power
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
SatNav Screen power
Evening All,
Hope you had a good weekend Very Happy
Well I'm back to playing around with the car and for that reason am looking for a 'protected'switched power source. What I mean is one that is not affected by the engine cranking on start up.
I would seem the stereo and SatNav screen have such a source and I'd like to tap into it if possible.
Therefore can anyone confirm that the power supply from the stereo to the SatNav is 12VDC, or if not what it is and also where I can find the +ve and -ve.
Thanks in advance.
Guy
PS I've got a 2006 SC 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #488528 Mon Feb 22 2016 7:51pm
Guyzer73
Hi no feedback?
I've determined the power feed it 12V so that's a start... Bit of a blonde moment as it's stated on the label of the unit... Embarassed
Now I only need to know which cables are +ve and -ve in the grey connector of which the picture below shows the 'female' receiver.
Alternatively if somebody could point me in the direction of a RRS electrical manual I'll search myself.
Thanks
Guy 2006 RRS S/C CONSTANTLY under modification...
Post #489816 Thu Mar 03 2016 5:46am
cigar lighter maybe ?
Post #489909 Thu Mar 03 2016 7:30pm
Guyzer73
Cheers Andy Thumbs Up ,
Problem with the lighter is that it suffers a voltage (I think) or current drop when you crank the engine. this when using the Tasker App is recognised as losing power and triggers various events depending on what you've set up, hence using the touch screen feed which I think is protected for want of a better word.
Also I want to use the touch screen power as this is in principle a switched (through the stereo) permanent feed meaning I could use the tablet without the key in the ignition, just the stereo on which I'd need anyway.
Thanks again, the hunt continues Thumbs Up
Post #489913 Thu Mar 03 2016 8:16pm
switched usually means you need the key in
Post #489915 Thu Mar 03 2016 8:25pm
Guyzer73
Andy,
in case of the stereo not. You can turn the stereo on by just pressing the left hand dial (volume control) this powers up the stereo and I think the touch screen also, no key required.
Post #489921 Thu Mar 03 2016 9:00pm
