![]() | Home > Maintenance & Modifications > Wheel bearing and front drive shaft required. |
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 ![]() ![]() ![]() |
I've just bought a few bits from Paddocks, good price and it arrived quite quickly, not sure about Scotland though. Only downside is they don't seem to have that many of parts for the RRS 2006 Java Black HST Supercharged |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9092 ![]() ![]() ![]() |
Advanced Factors on this forum. Always been quick and good prices. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4507 ![]() ![]() ![]() |
If you buy a new driveshaft, you will also need a new hub nut. The thread was changed at some point, and the old nit will no longer fit |
I was caught out with a different sized hub nut on my Discovery TD5 when trying to change the hub at the side of the road miles away from home. Had to go into a nearby garage and beg to borrow a socket! |
Martin0711 Member Since: 25 Jan 2014 Location: Buckie Posts: 45 ![]() ![]() ![]() |
Thanks for the info guys |
No, the one supplied with the new bearing is the old thread |
When changing the hub, after the bolts are taken out, can you just pull it off, or is it a press fit? seems to be conflicting info when ive looked into doing it! 2006 Java Black HST Supercharged |
Are you hoping to replace the bearing assembly ??
yeah, its just one sealed unit isnt it?
As long as the drive shaft has been pushed back then yes it just needs a good whacking.
Is a hammer easy enough, or would a slide hammer be a worthwhile investment? 2006 Java Black HST Supercharged |
A hamer was good enough for me mate. Id imagine a good quality heavy duty slide hammer would make it a little easier |
Thanks for the info Martin, i'll get myself a pair of hubs ordered now! |
No problem.
