![]() | Home > My Range Rover Sport > My first RRS tdv8 3.6 |
edviss Member Since: 29 Feb 2016 Location: london Posts: 28 ![]() ![]() ![]() |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9152 ![]() ![]() ![]() |
Front end knocking probably anti roll bar bushes. 2012 SDV6 - it's missing a couple of cylinders
cheers for reply. by reading your info below i got a bit shocked how much parts you have changed, in what period of time you have done all that? |
I've had mine for nearly 5 years now. Some of that list was caused by dealership incompetence.
i have read a bit about that "dynamic anti-roll bar system", is it expensive fix? or should i just leave it as it is? as i can see many people have this problem. thanks |
The bushes aren't expensive although a bit involved to change because access is restricted. Bushes seem to last about 30-40k miles if used on the potholed tracks that pass for our roads these days. I've had two or three sets over the years, last set only a few weeks ago.
Welcome to the TDV8 club by the way |
Cheers Camelrock |
this the ones yes? ![]()
Yes. Some of the more mechanically able members should be able to give some advice if you're planning on DIY. I've heard they can be a bit annoying to do. 2012 SDV6 - it's missing a couple of cylinders
Only use genuine LR bushes. It is not an easy DIY so best left to a specialist IMHO. Some of the bolts are inaccessible until the front driveshaft is removed and some other bits have to be moved too. The bolts are usually seized just to make things worse. Where are you in London? Perhaps someone can recommend a good LR specialist for you? 2008 MY Java Black TDV8 HSE
Had the front bushes done by my indie in January. About £150 on the road, from memory. 2012 SDV6 - it's missing a couple of cylinders
found this step by step document today |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
I thought my April 07 was the first TDV8...yours is 06??? |
