![]() | Home > Technical > Intermittent Cooling from AC |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
If the system is charged correctly and has no leaks then I would imagine the compressor would be the next item to look at 2010 RRS, TDV8
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 212 ![]() ![]() ![]() |
If the drier hasn't been changed in a long time or ever, then it may not be able to remove moisture from the system. If there is moisture in the air con system, water droplets will collect and freeze at the venturi of the evaporator on the high pressure inlet. As the water droplets freeze they block up the port and stop the circulation of refrigerant. The system then warms up as a result and the ice around the Evaporator venturi port melt, thus allowing the system to work as it should until the freezing up happens again. It will continue to cycle like this until the system is repaired. My advice is to go to a specialist aircon place, who should replave the drier and then vacuum the system down for a good hour to 'boil off' any moisture.
chassis Member Since: 23 Jun 2014 Location: Lagos, Nigeria Posts: 6 ![]() ![]() |
So I got the compressor replaced. It was a hell of a job for the workshop that fixed it. They had to remove all the turbo pipes and hoses, and still had a hard time getting the old compressor out. To top it all, a clutch type compressor was installed to replace the clutchless type. They advised that the clutchless type is more prone to failure and considering the effort and time required to install it, it's not just worth the risk installing another clutchless. The conversion worked well, the installed compressor (which works perfectly) now has a relay which controls it.
Personally, that's not an arrangement that I would be at all happy with. AFAIK, the swashplate design is not hugely unreliable at all, and is an excellent way of increasing efficiency. Most importantly, the system is integrated into the ECU systems so feedback from a binary clutch controlled compressor vs a variable swashplate isn't always going to match the vehicle's expectations.
A narrower belt is also something I certainly wouldn't entertain... Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
