![]() | Home > Technical > Cross over pipe 2.7 tdv6 |
It's been done: http://www.disco3.co.uk/forum/topic116505.html |
Williamsboy Member Since: 31 Dec 2014 Location: south wales Posts: 44 ![]() ![]() ![]() |
Hi Lost for Words
If that was the case then I would be tempted to go elsewhere anyhow depending how much warranty you have left with the garage that fitted the box. You don't have much to loose, if you have a problem after the crossover pipe is fitted then it will be upto those people to put it right. 2008 G4 RRSport TDV8 current
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5135 ![]() ![]() ![]() |
yeah I think I would try somewhere else.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
Having attempted it many different ways, I'd lift the body |
Hi guys thanks for your replies, with almost 18months of warranty to go on the gearbox my hands are tied. I have to use the garage that did the gearbox change, going to drop it off tomorrow morning (wednesday). As for taking the body off the Indie said they prefer to remove the gearbox to access the cross over pipe, even after explaining about the problems that could cause me with regards to the gearbox warranty. So i will keep my fingers crossed that they get this repair done quickly for me.
Hi Andy K , the cross over pipe takes the exhaust gases from the right hand manifold to the left hand exhaust manifold and into the turbo. The TDV6 only has one turbo where as the 3.6 and 4.o ltr have two.
My only concern would be that if it was them that messed it up before, what is to stop them doing so again? Is it not possible to find someone who would do it with the body off and leave the gearbox alone? Visiting from DISCO3.CO.UK
