![]() | Home > Technical > Clock on the Dashboard Problem |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Had the same problem when I had a low battery, was ok after battery was fully charged but had to do a hard reset by connecting the live and earth battery wire together whilst disconnected off the battery and that did the trick and also got rid of some other warning messages that used to occasionaly make an appearence |
As above, can be an early sign of battery issues, and a hard reset should bring it back. |
zaphod Member Since: 16 Jan 2015 Location: UK Posts: 290 ![]() ![]() ![]() |
Thanks chaps - would hope it's not a battery issue (no other warning lamps coming on) I only fitted a new Bosch battery about a year ago!
Probably just a glitch. It just happens when the Instrument Pack misses its sync with with the head unit which provides the time. |
