Home > General (L494) > Frozen doors |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
Silicone spray on the rubber seals helps to prevent this Nanocom Evo |
Sat Jan 16 2016 2:19pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Yup - aerosol tin of Halfrauds silicon spray - spray onto a cloth then wipe around all the seals (and there are a lot of them on a Sport).
Sat Jan 16 2016 5:10pm |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
I just use multi surface furniture polish. It gives the same result.
Sat Jan 16 2016 6:21pm |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 |
I had the same problem on a BMW convertible, where the frameless windows need to drop before the door can open. Following advice on a BMW forum I used gummi pflege. Absolute disaster! Muck everywhere and didn't solve the problem. I'll try silicone spray on the RRS. Might do it today as prevention, even if no problems yet. |
Sun Jan 17 2016 5:05pm |
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 |
Cheers for the tips I'll get some spray tomorrow. I think it was the very tops of the doors that were frozen not the actual rubber seals. theres a felt strip that probably should stop the water getting to the seals but its not doing its job so well |
Sun Jan 17 2016 5:30pm |
Get some liquid silicone lubricant used by plumbers (Wickes or B&Q etc) . Rub a little on all exposed rubbers/trim seals with a cloth. Cheap and really effective and doesn't attack the trim. |
Sun Jan 17 2016 8:34pm |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 |
or park it in the garage |
Sun Jan 17 2016 8:39pm |
I would happily keep it in the garage but no one told my house builder that some people own cars longer than a fiesta. i managed to get it in once while i was offshore but its too close for comfort to be putting it in and out every day.
Mon Jan 18 2016 9:43am |
I know the problem ! I have a similar problem length wise so I have two fixed breeze blocks on the ground that my wheels hit before I hit the wall. Carefully does it . |
Mon Jan 18 2016 11:19am |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 |
Same here ... mine has to stay outside as my car park is accessed via a lift ...
Sun Feb 21 2016 8:36am |
I Would move house |
Sun Feb 21 2016 10:20am |
