Home > Maintenance & Modifications > Still can't get these f**king exhaust tips fitted!!!&#12
J2D
Trying to fit these genuine exhaust tips to our 2011 HSE, pic below is how they match up to our existing exhaust, almost identical so can't get them to slot inside each other
So got some 60mm clamps as advised to go over both pieces, as below
These don't fit!! Too small!! Looks like they need to be 64mm!!!
Anyone know if I can get these in 64mm?? If so, can you tell me what the part number is please?
John
Post #488262 Sat Feb 20 2016 5:09pm
scrumps
John,
Not genuine LR but available on a well known auction site.
Search under "64mm exhaust sleeve" and take your pick.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #488267 Sat Feb 20 2016 5:43pm
Terryrrs
Looks as if you have a sleeve to fit over both exhaust and tips. Will they expand out a little as they do need to be fairly tight it looks as if you might have had the clamps over the tips if so try filing the outer edge of the exhaust pipe and perhaps cut a slot in it.
Post #488268 Sat Feb 20 2016 5:59pm
4X4BYFAR
This post has been edited by the site administration team
Not constructive in anyway. You are starting to annoy many of our members with your posts and pathetic comments.
First & last WARNING.
Post #488298 Sat Feb 20 2016 10:21pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I would think the clamp you have would expand 4 mm but if not pop down to you local exhaust place with the new tail pipe in hand and they will have them in stock I would think, even quick fit.
That way you will know you have the right part for the job and no need to wait for an order to arrive, Wink Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #488311 Sat Feb 20 2016 11:36pm
Buckster
Not sure where abouts you are in Essex but you could try Haywood and Scott Exhausts in Basildon. They have been going for about 30 years and are specialists at making stuff from scratch. I'm sure they could knock you up some sleeves and clamps for you or even fit them.
http://www.haywardandscott.com
Regards Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #488313 Sat Feb 20 2016 11:46pm
SH0X
Agree as everyone else has advised. Simple easy solution to that, and no more agro.
Alot of places that sell or do specific exhaust repairs will have some of these sleeves. Failing that get them welded on?
Post #488319 Sun Feb 21 2016 12:36am
J2D
Thanks for your help guys,
I can get these to expand enough to get them over both ends of the exhaust and tips, but can't quite close them enough to get the bolts back on, and with centre section and end piece of the clamps all needing to go on, it makes it very awkward! Gonna have another go at it this morning. 😉
John
Post #488344 Sun Feb 21 2016 8:37am
J2D
Finally sorted!!!! 😀
Had a couple of slightly longer bolts from some previous clamps I tried, just long enough to get them to bite and pull the clamps in enough to use the shorter bolts
Post #488435 Sun Feb 21 2016 8:12pm
tone 123
England 2005 Range Rover Sport Supercharged Java Black
hi john you can get sleeves of ebay. about 15 what I did is 62mm and 58mm that way one side goes over the exhaust and the other side goes in to the exhaust tips. and then clamp them on but you will need to measure yours exactly. Thumbs Up
Post #488437 Sun Feb 21 2016 8:23pm
PEACHY
Shocked at last Thumbs Up Well done Bow down Bow down Bow down 16MY Estoril Blue SVR.............
Post #488439 Sun Feb 21 2016 8:26pm
