![]() | Home > Maintenance & Modifications > Power steering oil ? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
The correct oil is not that much more expensive than regular ATF, I wouldn't take the chance
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Agree - there is a reason for lr to spec a special fluid for these pumps ( other than dealer margins) - you don't want something not compatible with the rubber seals etc. I was able to source gm belgium fluid that has the same texaco spec (for my '06) - not sure where you would get that in Europe however - but agree with above post - if you have dealer close, may as well get the genuine stuff - not worth the money you save to damage the pump ... |
