Home > Technical > Heated front seats - Help needed
dave421
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi All
I have a 2008 RRS, both the heaters in the electric front seats have stopped working (not worked since i owned the car). They have power so i have done a scan....
B1B65 - Left seat heater temperature sensor
- Permanent
B1B66 - Right seat heater temperature sensor
- Permanent
So my question is can i replace the sensors ? if not do i have to change the squabs ? how do i find out the part numbers?
Thanks for your help in advance.......
Post #487381 Sat Feb 13 2016 7:54pm
The sensor is part of the heating element. The elements are available separately and aren't expensive. I recently got one for my driver's seat from Duckworths - they're a sponsor on the site and you can find their info in the site sponsors section of the forum. Dan will need your VIN to be able to get the correct parts.
You will need to be able to remove / replace the seat covers. I got my indie garage to do this when the vehicle was in for something else to be done. Less than £40 which included putting the elements on a new cushion (I decided to get a new cushion too and bought a seat pan because mine was cracked). Removing the seat bases is easy enough - 4no T40 bolts on the underside and a connector (two for the passenger side as it has an occupancy sensor too). Don't lose the T40 bolts - they're not cheap when they come in a LR-branded bag! 2012 SDV6 - it's missing a couple of cylinders
Post #487471 Sun Feb 14 2016 11:30pm
dave421
HI
Thank you so much Very Happy I guessed it was part of the element but was not sure. I will get the parts ordered from Duckworths.
Thanks again......
Post #487581 Tue Feb 16 2016 12:12am
