![]() | Home > General > Suspension Stuck high |
Ride height sensor (look at the 4x4 screen, it may indicate which one it thinks is stuck)
Blocked dryer also fits. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4823 ![]() ![]() ![]() |
Thanks Guys
With the pump, but sounds like you've identified the issue anyway. |
So you think its a sensor issue ?
If you've been having trouble with that corner, then yes, probably a sensor/calibration issue. Airbag leaks can sometimes occur as they age, but otherwise they don't seem to give trouble. |
