![]() | Home > Technical > Flashers too fast right side, RRS 2.7 2006 |
Do you have LEDs fitted? Is it the external actual flasher that is too fast or just the flasher on the dashboard? Bodsys Brake Bible
41664166@online.no Member Since: 01 May 2015 Location: Moss Posts: 128 ![]() ![]() ![]() |
Have Led mounted both front and rear .
Where is the relay located ?
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
if its LED, do you have the Canbus style Led's? LED draw so little current that a car can think the bulb is not working, hence the rapid flashing |
How too fix that
I would assume you need to buy canbus style LED's or place a resistor inline
What about a flasher relay for LED lamps ??? |
In common with most of the lights, the indicators are controlled by in-built FETs in the CJB (passenger fusebox). You need not just CANBUS LEDs but proper resitors fitted to get a reliable result so if you don't have these then that's your issue. |
Where too buy and where too mount them |
50 Ohm ones are suggested to keep the amount of heat generated down - bear this, and water ingress, in mind in terms of location; can't be more specific not having a RRS I'm afraid. You should be able to source them from a typical electrical supplier. |
I have the LEDs fitted in the rear on my RRS 2006
Believe it or not, the legal flashes for indicators is between 90-120 flashes per minute.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
http://www.powerfuluk.com/range-rover-spor...r-kit.html
Strange I thought the still did, I didn't think they fitted indicators these days either as you never see them working. ![]() Cheers Col |
