Home > General > Detachable Tow Bars
SKAJ
United Kingdom 2007 Range Rover Sport TDV6 SE Java Black
Detachable Tow Bars
Hi. I need some Tow Bar advice. I intended to fit a Detachable Tow Bar to my 2007 Range Rover Sport 2.7 Diesel but I am hearing that there are concerns about the towing weight rating. I need to occasionally tow 3000kg. Your comments please.
Post #486664 Fri Feb 05 2016 3:17pm
3000kg is within the limits of the vehicle and the tow bar; both are rated to 3500kg. The possible issue is with the detachable tow head that can, in limited circumstances, come loose. If the tow bar is rarely used and is removed in between uses, kept clean and looked after, then you should be fine. Land Rover are contacting owners to offer them a free check and rectification so check with your local dealer if concerned. 2012 SDV6 - it's missing a couple of cylinders
Post #486667 Fri Feb 05 2016 3:53pm
Jaggs
Had the recall on mine earlier this week, all fine however they have reduced the permissible nose weight on a detachable bar to 150kg, a supplement is given to add to the hand book for future owners Nanocom Evo
Post #486680 Fri Feb 05 2016 5:55pm
The nose weight has been 150kg for a long time. 2012 SDV6 - it's missing a couple of cylinders
Post #486698 Fri Feb 05 2016 9:28pm
Jaggs
Just presumed it had been higher as the amendment says 'revised' nose weight of 150kg Nanocom Evo
Post #486699 Fri Feb 05 2016 9:37pm
