Home > General > Towbar
jono1976
Towbar
Does a 2010 RRS come with a towbar already fit then u just need 2 buy the swan neck etc??
Post #486628 Fri Feb 05 2016 9:15am
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
You'll have a hole for the tow bar so just need to buy a detachable tow hitch if there's not one in your boot. You won't necessarily have towing electrics fitted though.
Post #486649 Fri Feb 05 2016 12:50pm
does this apply to a 2005 too ?
Post #486662 Fri Feb 05 2016 2:09pm
Lost for Words
Yes. What's more, pre-facelift electrics don't need enabling to work, while facelift ones do. Thumbs Up Visiting from DISCO3.CO.UK
Post #486663 Fri Feb 05 2016 2:13pm
Thanks.
How do the parking sensors get disabled when towing?
Post #486695 Fri Feb 05 2016 6:56pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
They don't!
When you chuck it into reverse, there is a solid beep from the parking sensors.
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #486704 Fri Feb 05 2016 9:40pm
Bladeboy
Mine did that- then I turned the trailer electric socket round by 180 degrees and now it doesn't
Post #486756 Sat Feb 06 2016 11:00am
My MY08 turns off the rear sensors when towing. Front sensors continue to work. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #486759 Sat Feb 06 2016 12:06pm
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Bladeboy, you just want to check the trailer indicators aren't working in opposite directions to the car...I think mine did when I did that! My 2010 RRS has a silence button for the sensors Confused
Post #486779 Sat Feb 06 2016 3:02pm
Tim in Scotland
Both my 2005 2.7 SE and my 2007HSE Tdv8 came ready equipped to tow except they need the wireing connected up, the rrear sensors also got disabled when the electrics for the trailer got connected up to the socket, also the TDv8 had the first generation of the trailer assist bendy line that you followed on the screen to get the tow hook right under the draw of the trailer so all you needed to do was raise the suspension to get hooked on! Now it's a bit more refined and can detect snaking or something and is called Trailer Assist. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #486783 Sat Feb 06 2016 4:11pm
Bladeboy
They were Tim! That's what prompted me to fiddle with the connection!
Post #486789 Sat Feb 06 2016 5:25pm
Tim in Scotland
Have you tried blasting some compressed air into the socket when it's dry to get any road crud out that might have got lodged inside? I'm not sure how it detected that you had plugged the electrics in whther it was a sensor or a switch. Iused to have problems with m y last FFRR's trailer electrics after salt had been put on the road, but the socket for that was not as nicely integrated as the RRS/Dsico3 or 4's 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #486796 Sat Feb 06 2016 7:25pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
Andy K wrote:
Thanks.
Whilst the prefacelift cars tow electrics don't need enabling to work, if you get them enabled it will have the effect of silencing the rear sensors when a trailer is plugged in. Also, it will stop the suspension from adjusting if you have to tow through mud etc.
So yes, it will work, but my advice is to have it enabled. Mine is a 2006 car
Post #486803 Sat Feb 06 2016 8:44pm
