![]() | Home > Technical > Handbrake module replacement proceedure |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
I would question the way it was repaired and adjusted back up before I replaced the module, its very rare not to be able to fix the module.
| Bulldog Member Since: 11 Jul 2013 Location: Solihull, West Mids Posts: 112
I had it repaired at a garage whilst they were doing some other works.
That is adjustment and the correct sequence of resetting the module that needs to be done. You want to start by dropping all the adjusters off back to fully off, then you need to make sure the epb cables are nice and free, then make sure the epb is in the shoe fitting position with diagnostic tool.
Yes the fitting, adjustment and bedding in all done to the correct procedures which I got from Topix. |
| All times are GMT |
