![]() | Home > Maintenance & Modifications > Front Dynamic Anti-Roll Bar Replacement |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9124 ![]() ![]() ![]() |
I believe it's a body off job - or at least a body lift-a-bit anyway. 2012 SDV6 - it's missing a couple of cylinders
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Yes the ACE ARB Bush clamps have 3 bolts on each. And the rear one is imposible to get a socket onto it. So i think its a body lift job. |
Just had a look at the manual. Assuming you have a 4.2S/C, I've extracted the procedure and put it here:
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4520 ![]() ![]() ![]() |
Front or rear bar? |
I was refering to my Front Bar, I understand the rear
Chilly07 Member Since: 25 Dec 2015 Location: Central Coast, NSW Posts: 24 ![]() ![]() |
Oops!
Undo ARB links
You make it sound so simple! |
Thanks for this information. Ill be giving it a go Tuesday!! |
Well....started this morning. Followed Disco-Mickey advice. Definitely take wishbone off...so easier.
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Just about to do this myself and am ordering all the parts.
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 ![]() ![]() ![]() |
would of what?? |
Sorry fat fingers and small phone keyboard don't mix!
The bleed nipples are on the ends of the big drum part of the anti roll bar. One at each end and they at the top between the bolts that holds the thing together. Not sure how you bleed it without LR's magic box though. 2012 SDV6 - it's missing a couple of cylinders
