![]() | Home > Technical > Doesnt like going to access mode after tyres fitted |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2015 ![]() ![]() |
Might need recalibrating.....not sure but it's my hunch..... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
If using a jack to raise the vehicle it makes sense to put it in offroad height so you don't have to jack it up quite so far. There's absolutely no need to put the hazards on; the owner''s manual mentions it simply as a safety precaution assuming you are changing a wheel at the roadside. Leaving a door open is also not necessary .
chopperneil Member Since: 25 Aug 2015 Location: Kent Posts: 55 ![]() ![]() ![]() |
nothing showing on the 4x4 info screen when moving through all heights. I take it re calibration or diagnostic sessions are both main dealer visits?
Perhaps you're lucky and a sensor has sorted itself out; think they are just simple potentiometers and a bit of dirt can cause the problem until it rubs off?
Lets hope so for now Yes an IID tool is on my list of needs at some point! |
complained again today and came up with a suspension fault so going in to the local Indy tomorrow to be looked at and diagnostics read and a possible reset....... |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 ![]() ![]() ![]() |
My garage told me to lower to ACCESS HEIGHT. And lock it at that height. Otherwise the air suspension could pop out. |
We change tyres on RangeRovers regularly & I have never altered suspension & I've never had any problems at all.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
Change garages... The air bags are bolted at the top. Think about being off road - you often have a wheel hanging in the air without the springs popping out. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Only going off what I was told. Only had the car for just over a month. The Second day I had it I had a cracked rim so took it to local garage. |
