Home > General > Flat battery - advice
J2D
The wife only really uses the RRS for school runs (which is a couple of mins away), or runs around town (max 10 mins), and on the odd occasion it gets a 20min run at the weekend. Now with the cold weather arriving I was concerned about the battery, and planned to give it a charge this weekend. But got the call this morning it won't start (shame she will have to take the 10 min walk to school Rolling Eyes )
So, will stick it on charge this evening, couple of questions;
What battery do the RRS use? Sealed or maintained?
Is it worth me giving it a charge say every over weekend to keep the battery in good condition?
Are there any other checks I need to do to the battery or alternator?
Still has 17 months of the LR warranty remaining
Thanks in advance
John
Post #485359 Thu Jan 21 2016 1:40pm
B9BS X
Best to invest in a CTEK smart charger Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #485363 Thu Jan 21 2016 1:50pm
Lost for Words
The batteries are 019/017. Earlier vehicles are wet cell, later ones use AGM. If the former, you may be able to top up the electrolyte. The recommended option for earlier vehicles is: https://www.tayna.co.uk/EA1000-Exide-Premi...P7488.html (Discount code "D2BOYS" gets a few extra quid off.) Wink
The best thing you can do is put it on a trickle charger each night. A smart charger (e.g. CTEK) is ideal. Check the alternator is giving a good voltage and you can check for AC with a multimeter. You could check for a drain if you suspect one: http://www.disco3.co.uk/forum/topic119574.html Thumbs Up
Hope this helps. Thumbs Up Visiting from DISCO3.CO.UK
Post #485364 Thu Jan 21 2016 1:57pm
Sell the RRS to someone who will use it and walk the kids to school... Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #485371 Thu Jan 21 2016 3:06pm
ilard
If I was an eccentric millionaire and I didn't want the hassle, I would just have the battery changed along with the oil each year. It's only £150 or so.
Sorted. Thumbs Up L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #485377 Thu Jan 21 2016 3:39pm
J2D
Hahaha! Try telling that to my Mrs!!!
Post #485385 Thu Jan 21 2016 4:29pm
J2D
It's a 2011 model
Might sound like a stupid question, but what is an AGM battery?
Also, is it ok to charge the battery whilst connected to the vehicle?
Post #485386 Thu Jan 21 2016 4:33pm
Lost for Words
Absorbed/Absorbent Glass Mat: http://batteryuniversity.com/learn/article...ss_mat_agm Thumbs Up
Fine to charge in the vehicle, but in your case it's important not to place the negative lead on the battery terminal but on another ground point (e.g. in front of the battery box) so the Battery Monitoring System sees the charge. Wink Visiting from DISCO3.CO.UK
Post #485390 Thu Jan 21 2016 4:59pm
DrRob
John
Does it have tow electrics fitted?
If so, buy a CTEK charger from Halfords/Amazon etc and buy a tow electrics charging lead from the shop on here.
If no tow electrics fitted then use the ctek comfort lead on the battery. Plenty of threads on this topic on Disco3 forum Thumbs Up
Job done Thumbs Up * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #485395 Thu Jan 21 2016 5:31pm
J2D
I have halfords charger as I pic below, which I got from halfords before I got the RRS, will this be safe to use?
Not sure if I have towing electrics, how can I tell whether I have or not?
Using this halfords charger is it still important not to connect to the negative terminal?
Also, what exactly is the battery monitoring system?
Post #485411 Thu Jan 21 2016 7:30pm
Hamner
Wales
low battery
hi all , yeah my battery let me down at minus 4 the other morning got the rac out and plugged into his van and fired up straight away he advised to renew it so i did 85 quid and all okay again Thumbs Up ,ive had the rrs tdv6 for two and a half years so not bad
Post #485412 Thu Jan 21 2016 7:33pm
Jaggs
I've got battery cover from rac £20.99 and they fit a new battery for that if it's required.
My battery light just started coming on on a morning when I put heated screens on, I have a cigarette lighter volt meter which gives same readings as nanocom, it only reads about 12.6 on initial start up at idle but once I've driven 10 yards shows 14.6 and light goes out no problems starting but seems to be an issue somewhere. Nanocom Evo
Post #485415 Thu Jan 21 2016 8:02pm
scott2k21
Possibly time to replace the battery with new if keeps on discharging?
I had similar problem on my old 12 plate Autobiography where battery went flat a couple of times out of the blue after 3 'n a bit years. First time checks showed a higher than expected drain with a figure pointing to sat nav not shutting down fully. Pulling the fuse for sat nav seemed to reset that and drain value dropped back to 'normal'.
Annoyingly it went flat again within 4 weeks or so and this time all tests suggested all charging was ok and no abnormal drain when off ...original battery was replaced and seemed to solve it (before replacing with new model recently)
For reference my work is around 6-7 miles away so that was the daily drive, previously 3 miles each way without issue for a few years. Put it down to a deterioration of the original battery that a new battery could solve ...so assuming all your charging systems checked ok and acceptable drain on battery when shutdown this might be better option than recharging all the time?
Either way after experiencing this there's always the 'fear' of reaching for the start/stop button just in case you get greeted by the dreaded click...
Post #487339 Sat Feb 13 2016 10:29am
SH0X
Agreed re Ctek especially with AGM battery as has specific function for AGM
Post #488329 Sun Feb 21 2016 1:32am
TheWojtek
A more fancy name for trickle charging, I believe. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #488331 Sun Feb 21 2016 1:48am
