Home > Maintenance & Modifications > Terraclean
Disco_Mikey
So, Terraclean...
I did not use this company, they were the first page that popped up when searching for Terraclean benefits...
£108 + VAT for the fuel system treatment. I was sceptical before, but having heard lots of good reports, along with the additional benefit of carbon removal from the combustion chamber, my curiosity got the better of me... I even took injector readings with my IID to see if there was a difference in the way the PCM reported the car was running. Note the high readings on injectors 5/6
Had it done 11 days ago, and run 2 tanks of fuel through the car since it was done.
Took best part of 2 and a half hours to carry out on a cold and frosty morning. The car was already up to temperature when I arrived.
Not only could the operator not get the fuel pipes off the HPFP, he also could not find the correct pipes to fit. He did bodge something together, but I was not filled with confidence at this point. He also didn't know how to isolate the fuel pump, having claimed to have done a few 2.7's already...
So, eventually the machine was up and running, and the engine was running on a 50/50 mix of "premium" diesel and Terraclean cleaning agent. 20 mins of running at fast idle, followed by a 20 minute "soak" period, and another 20 minute fast idle
The car stunk. This is normal he claimed. It is normal, my car doesn't have a cat fitted Laughing
To achieve fast idle, a pole is inserted between the throttle pedal and the seat. Occasionally the revs would increase and decrease of their own accord. This was due to the cleaning process. Nothing to do with the TDV6 throttle pedal Wink
Didn't smoke any more or any less before, during or after the treatment. Pipes disconnected, fuel pump reinstated, and was told to give it a good, hard run, after spelling fuel all over the engine, which smelled suspiciously like Kerosene, as found in injector cleaners
Initial impressions were Neutral
The car behaved exactly as before.
No better starting. In fact, it made it a little lumper on a cold start
No quieter running. It's a big Diesel engine, it's not going to be particularly quiet
Smoother idle and pick up. It idled fine when warm, so no difference. Pick up was no different, but the car has an Alive remap already
Improved power and torque. The bum dyno reported no significant gains. Gary @ Alive is planning on doing some Before + After dyno runs at some point in the not too distant future, I believe
Improved economy. Fuel economy stayed exactly the same, at 25.5-26mpg over those 2 tanks with similar driving and routes. I saw a better increase in economy with previously mentioned remap
Less exhaust smoke. It is fairly smokey anyway with no cat, no EGR, and a remap. No significant reduction was noted
Reduction in flat spots. Again, remap made a much bigger difference to this
Lower emissions, reduced carbon build up and prolonged engine life are all subjective.
Emissions are tested once a year, and any car that fails the test has issues. Normally, a dose of injector cleaner and a good thrashing cleans them right up
Reduced carbon build up is unseen, and cannot be judged
Engine life is determined by servicing. Neglect the servicing, and it will cause you issues. Terraclean won't fix a worn engine...
Honestly? It was £130 wasted, IMHO
However...
TDV8Mat wrote:
The Terraclean process atomises carbon deposits, so effectively turns the carbon into vapour, which is in turn exits through the exhaust.
I have done 200-300 Terracleans, and I always ask for feedback when they have driven the car for a few weeks/miles. Everyone who has had it done has seen improvements in at least one area, whether it be MPG or throttle response etc.
It is very easy to slate this product - but I find 99% of people who do - haven't had it done Rolling with laughter
My main point of trying out a Terraclean was the removal of carbon deposits. As you may or may not know, the TDV6 suffers from glow plug issues. When the plug stop functioning, the reduced heat allows carbon to build up around the glow plug. I tried to remove my glow plugs after the clean.
Last attempt saw 3 come out OK, with the other 3 seized.
After the clean, 3 came out OK, and the per 3 were still seized
Post #485266 Wed Jan 20 2016 9:53am
Drinky
England 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Interesting, maybe it is a case of 'wanting it to work'? I'm sticking with my initial comments though, my T5 definately ran quiter and felt livelier.
Post #485268 Wed Jan 20 2016 11:01am
Lost for Words
The placebo effect can be every bit as as powerful as the real thing. Wink Visiting from DISCO3.CO.UK
Post #485274 Wed Jan 20 2016 11:44am
TDV8Mat
England 2013 Range Rover Sport Supercharged HSE Santorini Black
Fair do's Mikey - can't argue with that. I guess on some individual engines it works better than others 2016 RRS SVR Estoril Blue
Post #485275 Wed Jan 20 2016 11:46am
Disco_Mikey
I imagine if its a town car, that never gets a chance to get hot, or worked hard, then a bigger difference would be felt
My car is out on the road pretty much every day, doing 30k+ a year, and it does work hard
Who knows. My advice, is put the money towards a remap. Much better Thumbs Up
Post #485281 Wed Jan 20 2016 12:25pm
Brutus
England 2006 Range Rover Sport TDV6 Autobiography Java Black
[quote="Disco_Mikey"]So, Terraclean...
What a great post. Fantastic detailed research. Where else could we possibly receive such dedicated commitment regarding our vehicles. And It's free.............. Very Happy Very Happy Very Happy
Post #485283 Wed Jan 20 2016 12:41pm
ilard
It would be great to do this level of testing with a low milage, city car.
I now always use premium fuel as I only do 5,000 miles a year. I hope it helps, but who knows? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #485320 Wed Jan 20 2016 10:19pm
Bodsy
Site Sponsor
That's really usefull feedback Mike Thumbs Up
Thanks for putting your money where your mouth is and having it done.
I'm even more convinced now that It's just not worth it Thumbs Up Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #485323 Wed Jan 20 2016 11:24pm
