| RRSPORT.CO.UK | ||
|  | Home > Technical > FBH |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | The best thing you could do is get a diagnostic tool, check and clear the codes. You can also reset the FBH by removing fuses , then refitting but I carn't remember which,maybe some one will be along who can tell you which one. Finally I'd try a hard reset. Remove both battery leads from the battery and briefly touch the leads together (keeping both away from the battery posts) then refit and test the FBH if still no joy then you need the fault codes.. 2008 G4 RRSport TDV8 current
|  Fri Jan 15 2016 10:41pm |
| Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380      | Hi, not to rub salt in but mine has been coming on and what a difference it makes, nice and warm in a short distance and time   | ||
|  Fri Jan 15 2016 10:50pm |
| myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433    | Mine also, not wanting to make Panavia man feel bad but with mine you could buy the whole RRS and have a fully working FBH, both timed and remote - and the heated steering wheel of course. Great for winter.
|  Sat Jan 16 2016 7:00am |
| Panavia man Member Since: 27 Oct 2015 Location: North west Posts: 94      | Thanks for the replies. Will probably take it to the local Indy for a reset first then. | ||
|  Sat Jan 16 2016 8:10am |
| Posting Rules
