Home > Technical > Steering wheel wobble under braking
TTF
I have read a few threads on here but nothing quite giving a solution to my problem!
I have a 2010 3.0 TDV6 HSE which is wobbling under braking. It is not tyre balancing as it only happens under braking. I have replaced the front discs and pads (old ones were slightly warped), front lower arms (some play but not dramatic) and front wheel hubs (old ones were slightly warped) but it is still there.
There is a Land Rover bulletin saying that under such circumstances the process is to change the discs & pads, then lower arms, then hubs, then steering rack and then steering wheel (weights in the steering wheel can become unbalanced?!). Typical Land Rover, no direct solution, just a bloody good way to earn money on parts!
So I am at least £1500 down and f***ed if I am going to spend another £1500 on a reconditioned steering rack and steering wheel.
Can anyone help?!?!?!
Post #484625 Tue Jan 12 2016 6:31pm
Have to be honest Never heard of Steering Wheel weight's or balancing.
Post #484626 Tue Jan 12 2016 6:52pm
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Well beyond my pay grade, but I'd still put my money on warped discs. Worth checking the rear ones?
Post #484630 Tue Jan 12 2016 7:20pm
TTF
Nor had I, but apparently that is what it says on a LR bulletin according to Autologic!
Post #484631 Tue Jan 12 2016 7:20pm
TTF
Rear ones shouldn't cause the wobble through the steering wheel, should feel it through the seat? What is worrying is that there is a specific LR bulletin about this specific issue, but no conclusive solution! Sounds like a Land Rover!
Post #484632 Tue Jan 12 2016 7:22pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Warped discs would mostly be felt as pulsing through the brake pedal ...wobble could be worn lca bushings - tie rods - etc. I'd take it to a different indie - or suspension shop familiar with lr and get their opinion.
Post #484640 Tue Jan 12 2016 9:35pm
TTF
The car is going into a different garage tomorrow; anyone had any similar experiences or known remedies before I drop it off?! Thanks.
Post #486420 Wed Feb 03 2016 12:38am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
TTF,
I understand another option to try is a complete 4 wheel alignment.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #486544 Thu Feb 04 2016 9:57am
TTF
I think that is one of the plans but I cannot see how the alignment will affect a wobble only under braking and only through the steering wheel and not the brake pedal?!
Post #486545 Thu Feb 04 2016 10:00am
