Home > General > Gearbox issue
l200jmc
Gearbox issue
Hello there, I have a rr sport 2007 tdv8 and seem to have an issue with the gearbox. When driving cold the box seems to run fine, once it's warmed up it holds the higher gears and doesn't want to shift up, for example when driving along at 70 it will either stay in 4th or 5th. Manuel mode works fine and if I knock it into sport then back into D it go's back into 6th. I have had the box oil changed and new filter but problem is still there. Ive herd the oil cooler can sometimes cause these problems. Would a power flush solve this or any ideas welcomed... It's covered 146k thanks jamie
Post #484179 Wed Jan 06 2016 7:41pm
l200jmc
I have also been getting a water in fuel message on the dash, took it for service with genuine parts and the faults still there I don't think there's any water in there as it's been running fine... Any ideas on how to fix this thanks jamie
Post #484180 Wed Jan 06 2016 8:04pm
aldomaximillian
A power flush probably wouldn't help. Ive had one done and it makes the gear changes smoother but didn't fix the issue. It sounds like your gearbox just isn't engaging from 4th to 5th. Mine is the same. Bad news but you will probably need a new gearbox if you want the issue fixed. Saying that, your gearbox will carry on fine like it is for a long long time still. Get the power flush just so it doesn't get worse. I normally just put the gearstick into manual mode and switch it upto 5th gear, then put it back into auto mode. Hope that helps.
Post #484238 Thu Jan 07 2016 8:38pm
Disco_Mikey
Brake switch and/or bulbs can cause a similar issue, and a damn sight cheaper than a gearbox rebuild Thumbs Up
Post #484249 Thu Jan 07 2016 10:17pm
l200jmc
Hey thanks for the replys, how would I go about checking this Mike? Thanks
Post #484256 Fri Jan 08 2016 12:21am
DrRob
Do a search on here - lots of info Thumbs Up Visitor from fullfatrr.com
Post #484272 Fri Jan 08 2016 10:35am
