RRsport alternator help
Hi, had the multimeter on the battery terminals today, with all the lights and heated seats on, and was reading 12.32V. Does this indicate that the alternator is struggling. It's a 2008, RR sport, 2.7 hse. Thanks Adam.
Wed Jan 06 2016 5:12pm
Bodsy Site Sponsor
Definitely. Yes. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE
Wed Jan 06 2016 5:20pm
pinnch
Ok thanks, just thought I'd check. It's going for a new alternator fitting tomorrow at York land rover services foŁ350 fitted. Cheers
Wed Jan 06 2016 6:33pm
alpaca
Voltage should read at least 13.4 or so with alternator running at idle speed and load (lights etc.). If you are reading 12.2 you are probably only pulling power from the battery which will not run very long (perhaps 30 mins if not being charged). You can drive car if voltage is >13.4 if you reduce load or run at higher rpm than idle - else battery is probably not charging and will
Die.
Btw - alternator electronics do no like heat from the engine bay - I had to rebuild alternators on my porsche and bmw (both bosch) at around 60k miles - so not unusual for these things to burn out eventually ...lucky you caught it before being stranded on side of road ...
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
