| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > 2015 Range Rover Sport Shark Fin antenna. |
| shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948      | Can you tell us what part numbers/cables we need? and more importantly how you did it  | ||
|  Tue Jan 05 2016 12:32pm |
| TheWojtek Member Since: 08 May 2015 Location: PoznaÅ„, Poland Posts: 752      | I am particularly interested in an idiots' guide to removing the headliner. Regards etc.,
|  Tue Jan 05 2016 3:00pm |
| ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698      | To remove the  rear section ( to do it properly ) without creasing it, Remove both rear boot side wall panels these are the carpet side panels they are only clipped in. Once removed you then remove the rear upper panels covering seat belts. Then Unclip the edge of the headlining to expose the shark fin installed. Unplug the cables all cars are different you may have the single cable or 2. Then remove the 2 bolts securing the shark fin then it can be pulled away from the car roof.
|  Tue Jan 05 2016 4:24pm |
| shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948      | indeed it does  | ||
|  Tue Jan 05 2016 4:32pm |
| TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 752      |
    Thanks. Will defo try this once the temperature goes into plus regions... Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE | ||
|  Tue Jan 05 2016 7:26pm |
| rajranjit Member Since: 09 Dec 2017 Location: Devon Posts: 2    |
 Hello can you please let me know the part number and how much it cost you. I live in Newton Abbot. Where did you purchased the part Many thanks | ||||
|  Sat Dec 09 2017 10:55am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | I replaced my RRS1 one with the Shark fin one from the RRS2, twice in fact because the Sat Nav side of it failed both times, they were bought new from dealer not second hand. Whether I was just unlucky and they were faulty units and just failed or they are not really compatible with the RRS1 electronics I don't know, they did last a few months each time . Fitted a new original fitment one and has been perfect ever since. The part number of the RRS2 one I used is LR059756 if you want it.
|  Sat Dec 09 2017 8:53pm |
| rajranjit Member Since: 09 Dec 2017 Location: Devon Posts: 2    | Thank you very much. It’s great help. Let you know how I get on. | ||
|  Sat Dec 09 2017 10:51pm |
| Posting Rules
