![]() | Home > General > Dynamic Mode |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
May be completely wrong here but isn't DSC on all the time unless you manually disengage it with the switch?. As I say just goes to show how much notice I take.
Have I missed something? Can't see DSC mentioned, Col? |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
Happy New Year to all! Col, I reckon Nigel means the Dynamic mode on the wheel by the handbrake. I have it on my 60 plate but it wasn't on my 07 plate.
Thought Dynamic Mode and Dynamic Stability Control would be the same thing.Guess not.
Dynamic mode is the button you press along with the sports gearbox and make use of the flappy paddles when you want the RRS to become a Sport, and have an enthusiastic run on your favourite road. |
I use it on twisty roads. Tightens everything up |
Probably being thick here but which is actually Dynamic Mode button then as opposed to the DSC one?.
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 ![]() ![]() ![]() |
Absolutely this is one of the main differences between the RRS and say ML, X5 or any other 4x4. Current Merc GLE 3.5d 2016 model, 2011 RRS HSE standard
The button behind the handbrake with the 《 》 on it. Press the left hand 《 and look on the dash control panel behind the steering wheel and it will say Dynamic Mode. Press it the other way 》 and it goes through the other modes... Sand & Gravel etc etc. |
O.K found it guess I should have read handbook first |
stornoway10 Member Since: 03 Feb 2013 Location: Southport Posts: 60 ![]() ![]() ![]() |
Dynamic setting is top row, leftmost setting
Happy New year Nigel |
Dynamic Mode doesn't just pin the car down harder on the air springs it also "weights up" the electronic power steering on RRS2 and changes the throtle and toque vectoring maps IIRC. You don't have to be in Sport mode to feel the difference either, that just adds even more responsiveness to everything as well as the "manual" gear shifts. The change between "normal" and Dynamic in the RRS is much more marked than it is in the Evoque Dynamic, I suspect that having the air springs is the reason, the Magneride in the Evoque works well but not as markedly as in the RRS2. I complained to LR that the Dynamic mode in my 1st Evoque got very confused when driving on rippled concrete motorway surfaces and made the ride really unpleasant............... the response was "why are you using it on motorways? It is meant for twisty roads!" |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Yep i loved the Dynamic mode on my previous 2012 RRS. For a 2.7 ton car, it really does handle well. |
