![]() | Home > Technical > Sway bar problem |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9092 ![]() ![]() ![]() |
The anti-roll bar should not be leaking at all so that is a separate issue to the noise. If the leak is from the pipe connections to the unit then you might be lucky and be able to replace the seals. If it's coming from where the bar itself comes from the main body of the unit then you're looking at a new anti-roll bar. The anti-roll bars are several hundred pounds and require the body to be lifted to change them.
Tizzard Member Since: 30 Nov 2015 Location: Nottingham Posts: 64 ![]() ![]() |
Thanks for your input rrstdv8. I didn't no if the knocking could be coming from the anti roll bar due to it leaking. I think I will get it booked in Monday and see if the unit will be covered under the warranty. As I no the bushes won't be so will so how I go. It is leaking from somewhere around the main unit but couldn't tell where from.
I'd bet you a tenner now the warranty won't cover it... Visiting from DISCO3.CO.UK
If it's the LR-branded car care plan warranty then it should cover the bar but not the bushes. 2012 SDV6 - it's missing a couple of cylinders
