![]() | Home > Photos, Videos & Media > Heavy steering |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 ![]() ![]() ![]() |
Hi Barry,
I have a 2012 with 22's & a 2012 on 19's & the steering on the 19's is a lot lighter due to tyres not being as wide.
When the topic of intermittent heavy steering has come up previously the experts usually attribute it to a partially seized universal joint in the steering column. A diagnostic and temporary fix is to spray liberally with WD40 or similar; but for a permanent fix replace the joint. 2008 MY Java Black TDV8 HSE
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
Had the same on mine with intermittent stiff steering. Changed the shaft and universal joint.( all as one piece). It greatly improved handling, the uj was knackered and had masses of movement. The part is less than £100 for genuine part. |
