![]() | Home > Maintenance & Modifications > Problem replacing tailgate trim |
jmcvs Member Since: 26 May 2014 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
Hi, if its the lower tailgate trim where the letters are, it just clips back into place, make sure the clips are all good and give it a tap back on |
rrobyrroby Member Since: 07 Mar 2015 Location: Reykjavik Posts: 5 ![]() ![]() ![]() |
It looks like I have some pins on the ends to slide in, so I just cannot push.. |
You do not need to slide the trim on, the black clips that are still in the tailgate come off and fit back into the trim. here is a you tube video that should help you -
